24h Prime 95 tests are pointless. I run IBT on the high setting and call it done. It takes about 5 min and then I am done. I almost never have stability issues with any program after running IBT on high, and running P95 for 24 hours adds nothing of value to me. On the rare occasion that the computer does lock up, I just add a bit of voltage and then it works fine again. No reason to spend forever determining what can really be determined in 5 minutes.
Yes, yes someone I going to say that's BS and 5 min does not prove anything, but my experience says otherwise. That's the only type of stability testing I've ever done and I've been overclocking since single core CPUs were the top-tier and it's always worked fine for me.
- - - Updated - - -
This is what I do:
Set voltage at 1.3v
Set clock at 4.6 Ghz.
Run IBT on High.
Restart computer and increase clock in 100mhz steps until computer crashes.
Downclock 100 Mhz, add 0.3v and then call it done. Works perfectly fine and takes less than 30 min for the whole thing.
