- Dec 30, 2011
Sitting here installing rutorrent on a remote server and I happened to notice my temps were running almost 100c. Shut down and turned off the power let it set a while. Turned it back on looked in the BIOS to see what it says, showing 32c. Boot back up to windows and temps are around 70c Reset bios to default settings, same thing. Cleaned out the fan (not that it needed it but did so anyways) put on new paste (MX-2 arctic) and no change but my display driver started crashing (Display driver nvlddmkm stopped responding and has successfully recovered. from error log) after a crash the temp would drop back down to normal but the temp went back up after recovery. I got my drivers removed reinstalled, even moved the GPU to another slot and the temp dropped back to normal. It didn't last long though.
Comp build
Case is antec nine hundred 3 cpu fan is evo 212
This is before all the troubleshooting.
This is after
This is right now
Field Value
Sensor Properties
Sensor Type Nuvoton NCT6776F (ISA 290h)
GPU Sensor Type Diode (NV-Diode)
Motherboard Name Asus Maximus IV Extreme-Z
Chassis Intrusion Detected No
Temperatures
Motherboard 39 °C (102 °F)
CPU 44 °C (111 °F)
CPU Package 72 °C (162 °F)
CPU IA Cores 72 °C (162 °F)
CPU GT Cores 72 °C (162 °F)
CPU #1 / Core #1 68 °C (154 °F)
CPU #1 / Core #2 73 °C (163 °F)
CPU #1 / Core #3 70 °C (158 °F)
CPU #1 / Core #4 70 °C (158 °F)
GPU Diode 51 °C (124 °F)
ST3200822AS [ TRIAL VERSION ]
Hitachi HDP725050GLA360 [ TRIAL VERSION ]
Cooling Fans
CPU 1953 RPM
Fan #1 979 RPM
Fan #3 974 RPM
GPU 1260 RPM (21%)
Voltage Values
CPU Core 1.352 V
+3.3 V 3.376 V
+5 V 5.040 V
+12 V [ TRIAL VERSION ]
+5 V Standby 5.212 V
CPU PLL 1.806 V
VCCSA 1.072 V
South Bridge Core 1.058 V
South Bridge PLL 1.058 V
DIMM 1.515 V
iGPU 0.615 V
GPU Core 1.025 V
Power Values
CPU Package 106.53 W
CPU IA Cores 101.64 W
CPU GT Cores 0.35 W
What can I check/test for? My IDLE temps range from 26-32 depending on what the temp is in the house at worst these temps are when I am playing games and I was over clocked to 5ghz range. I am on default settings right now
Comp build
This is after
This is right now
Field Value
Sensor Properties
Temperatures
CPU 44 °C (111 °F)
Cooling Fans
CPU 1953 RPM
Fan #1 979 RPM
Fan #3 974 RPM
GPU 1260 RPM (21%)
Voltage Values
CPU Core 1.352 V
+3.3 V 3.376 V
+5 V 5.040 V
CPU PLL 1.806 V
VCCSA 1.072 V
DIMM 1.515 V
iGPU 0.615 V
GPU Core 1.025 V
Power Values
CPU GT Cores 0.35 W
