Ok, so about a month ago I made my first watercooling setup. It looked like this...
The water itself looked horrible so I knew I was going to refill it and get a new motherboard, and what better time to get rid of the worthless res and get GPU cooling in the loop? So an order to DD and a DFI nf3 250g later I redo the whole setup and got this.
I like the T line much better than the res when it comes to filling, and the bleeding only took a little time. Temps got a little bit better also. They are now CPU 27c GPU 28c idle and 31/34 full load. There is a slight kink after the GPU but with my temps im not really worried about it. Unless somone really thinks differant and tells me.
The setup is d4 -> dd double HC -> a64 TDX -> maze4 GPU -> T line (dd fillport)
Anyway today I finally had a day off and could set up my UV lights. After almost killing myself making the front switchs for them....
I got them all set up, first the front
Front with open door, notice the switches for the UV lights ooo
also the front grill detatched.
closer w/ CPU thermal probe reading (27.2)
Now with the UV lights `~
Thats it!
Any comments/questions/suggestions?
Thats it!
