- Sep 15, 2015
- Pensacola, Fl
I swear this craps like bubble gum. What should I use/do to remove it from the chip?
Heat it up with a hair dryer. It'll soften up and just peel it off from the sink. Use alcohol and qtips to soak it on the chip, then scrape it off with something thin and plastic.
Geez what are you load temps? Got enough rad?
I use alcohol and a toothbrush. Works great and soft enough you won't knock and of the resistors etc.. loose. Then final clean with a coffee filter. I use this a lot on GFX cards when swapping cooler to block sometimes the TIM gets a bit messy around the chip.
Now the look my wife would give me, seeing me cleaning my motherboard with gas would be classic!!!!I have tried 99% Isopropyl Alcohol, 100% Methylene chloride and that pink stuff stays hard as a rock unless I used gasoline.
Well it came off the chip easily enough using a heatgun and some isopropyl, but now that I'm considering replacing the aftermarket sinks with the stock ones I guess gasoline could be fun.....
How long have you had your board DNRDustin?
Curious as to how long this termal paste stuff lasts in a mobo...
