- Dec 29, 2003
- Israel
well, i think i might hate this board now... a pain in the *** finding a cooler
bought a ANTEC 620 water cooler last night, ran if for few hours and the pump noise drove me mad, not loud but somehow just annoying
i have located a AXP140 but as it turns out its too tall for the elite 120
need to keep the cooler under 76mm
have the "list" of coolers that fit
https://docs.google.com/file/d/0B3jruY0yVasgUDc3dUZZN1FJRGs/edit
so what to buy?
Noctua NH-L12 - fits the board but blocks the pcie, but i found out you can bend it a little and it will free the pcie
Praeton LD964 - looks nice, cheap, but i have to order it from UK and ship it here. there reviews for him are "so~so" and i'll have to get a normal 92mm fan to make it work
Zalman SZ CC92HS - cheap alu cooler, will fit 100% and be more silent then the intel stock i use right now, but being "unknown" cooler makes me worry, also don't know it the alu cooler can work well with my 3570K (yes yes... i know)
Scythe Shuriken Rev. B - looks good, small, but i don't know that it will fit 100%... can't find someone that used it to be sure
Noctua NH-L9i - i think "how low can you go" was made for this cooler, low as hell but expensive, don't think its a good option
Scythe Big Shuriken 2 Rev.B - any chance it will fit?
any other good options?
so what to buy?
