You can use the mouse because the board has UEFI BIOS technology.
What are we talking about? For CPU power, only one is needed unless you are going extreme cooling. If we are talking supplemental power to the PCIe slots, and you are mining or running multiple GPUs, then yes, plug it in.Definitely plug them both in. It is apparent that you need as much current as possible.
Yes we are. So I only need the 1 Power pin for CPU?What are we talking about? For CPU power, only one is needed unless you are going extreme cooling. If we are talking supplemental power to the PCIe slots, and you are mining or running multiple GPUs, then yes, plug it in.
Since no one else mentioned it, I would shy away from going crazy upping the BCLK. Upping the BCLK overclockers everything including PCI-E busses for your video card and SATA ports for your hard drives. Going higher than stock increases the risk of frying your video card, losing a hard drive, or corrupting your RAID controller. Keep the BCLK at stock (or no higher than 103) and go with your multiplier or RAM timings for overclock.
ED, he's wondering if he needs just four pins or all eight.For the CPU (8 pin around socket area), just one. With un powered risers, if the board has supplemental power lead for multi gpu setup (sometimes sata/pcie/or even molex), use it. With powered risers, you would not need to.
EDIT: That said, your HD4 has NONE of those options even available.....Im confused...
For tweaking, sure why not, but do not expect performance gains with it (so, for me, I don't waste my time) for how you are using it. It can only lead to instability honestly. Id leave it at stock, especially if this is your miner...
Really? I thought the timings really affected performance?
That's because random relies on seek time more than throughput.
Seek time is determined more by timings.
Hmmm! Okay I have more reading to do it seems!
Noticed your sig memory, looks like stock timings to me.
Did you ever tighten them to see if there is a real difference?
No need to, gains from 1600 CL9 9-9-24 2T are negligible. Especially considering the time spent and stability that could be lost.
