- Mar 25, 2011
- Pacific NW USA
I only quickly read Bubba's long post. Skimmed rather. Not sure about the AMD route.. The FX line is just not worth it when you can get a nice cheap H77 board and pair it with a 3450 and get the same result. A 3450 at stock is probably equivalent to 4-4.2ghz FX 6100; minus the extra performance thread-wise. Which even then I wouldn't be surprised if the FX lost. And also considering the 3450 without IGP will max out at 50w; vs the FX 6100 130w+ rating and once OC'd goodbye power conservation.
But I do like you've gone back to the Intel route . I do agree on the 2500K though; I myself actually bought a Z77 board and the 2500K at the same time, simply because the 2500K required less cooling for a nice OC then the 3570k. And for a gaming rig; made no difference.
But for single screen gaming at 1080p; and for a gaming rig only; the i5 3450 will do perfectly fine. OC'ing really doesn't help a lot for 1080p or less. It really only helps some badly threaded games where higher clock speed means more; but even then 3.5ghz isn't slow for an Ivy proc (turbo mode). If the OP isn't comfortable with Oc'ing; or has no desire to; I see little reason to buy him an overclockable CPU. Though I would stick with that board you picked; just because its only 20 ringits more expensive than the H77 version. But the 3450 is almost 100 ringits less than the 2500k. But again if the aim is budget; the drop to the H77 paired with the 3450 is still the better choice. Over 100 ringits saved for (at stock) slightly better performance and slightly lower consumption (though negligible)
The FX series have really gotten a bad rap from for the most part fanboy spin and poorly done reviews. You have to remember that most reviews that came out were done A)Pre Patch and B)at stock speeds which ignores one of the FX's main strenghts. If the prices were similar where he's at and an i3 cost the same amount as an FX-6100 here I would have easily recommended to him. But when I saw that it's more expensive than a 2500K my jaw hit the floor, those prices are rediculous. Same goes for the locked i5 series. With the 6100 cheaper here than the locked i5's and give similar or slightly better (better in multi-threaded apps) it's a good option vs those i5's. With the kinds of prices he has it changes things drastically.
Do you know anyone with a 3450? Now I'm curious to see how they compare to each other. I'd love to run CPU bound benchmarks with someone and see how it all pans out (preferably someone objective and we can just run an objective comparison without any biased opinions on either chip).
= =" wao i gone for college for like 3 hours and the amount of essay has came out lol, really appreciate the help guys.
Actually my total budget its RM 2200 if possible no more (havent include GPU , i getting all other parts first , i will have to suffer with my Sapphire 5830 Xtreme 1GB with my new PC build at the moment)
So i should change to Seasonic / Silverstone PSU instead then ? Cooler Master aint bad too i seen many Americans used them. Maybe its not so popular there, but most actually uses Cooler Master , i can get a 650W 80+ BRONZE too from RM 279 for Cooler Master
Bubba how you know of Compuzone ? I actually is taking the price from there lol , but they dont sell the PSU and CPU cooler i want from there.
But i be buying most parts from that shop. So you guys can take a reference what my country here got and the price from that price list.
But as i mentioned before very earlier , well i know this is a OC Forum , but sadly i dont OC , i dont tend to OC too....so i dont think there's any point i getting a 2500 K since i wont OC it. So my question stands , is 3550 worth the extra 55 bucks compare to 3450.
Another thing it worries me , i just actually found out the H77 and even the Z77 Mobo from Gigabyte its actually a Micro ATX , i was wonder since its smaller, i worry my GPU will touch the HDD cage of my casing , will it ? Or since the Mobo is smaller you will actually place it lower than the normal size ATX Mobo , i hope you understand what i mean.
I just want a PC which my hardwares either the GPU / CPU or any what so ever , will bottleneck my other parts or anything.
I want a PC able to play all most recent 2012 released games and upcoming 2013 games, with MEDIUM to HIGH graphics , i don't even demand ULTRA. If possible maybe my PC can still last for all the games for the next 3 - 4 years (starting from now 2012 )
Thats all i want , i want a gaming PC , but not a hardcore extreme gaming PC , since its aint cheap to get a PC here actually , dont know about US , if i include GPU now total build be like 3 K then.
That being said , to show how hard to build a PC here, simple , a Manager salary here maybe only 4 - 6 K per month ! Im still a student and im building a PC worth 3 K !
Unless your a business man , i think money will come easier then well if you have good business daily.
One most last thing , let's not forget to add in a new copy of Windows 7 64 BIT costing RM 269 =)
( i wonder is it even 64 BIT on the price list if its 86 BIT.....****..... even more expensive than i calculated then)
I just did a search in google for "malaysia pc parts" and I think it was the 3rd result down in the list. I figured since they had a shop in the capitol that most people there have heard of it and so I downloaded their price sheet.
So, with OC'ing not being a factor and a budget of 2200 ringgits I would have recommended an i5-2400 but since there the 3450 is the same price then the choice is easy. You really won't see a difference between the 3450 and 3500 in gaming. With all of that in mind I'll update the list to this
CPU - i5-3450 $575 ringgits
MB - GIGABYTE H77M-D3H $299 ringgits (make sure to upgrade the bios to F5 if it doesn't come with it)
Mem - 1600C9 VENGEANCE $229 ringgits
PSU - Either of these
Corsair 600W GS ( A/80+ ) $279 ringgits (before anyone decides to knock corsair read the review)
http://www.hardwaresecrets.com/article/Corsair-GS500-Power-Supply-Review/1571/11
OR this
Seasonic 620W S12II ( A/80+ ) $299 ringgits
http://www.hardwaresecrets.com/article/Seasonic-S12II-Bronze-520-W-Power-Supply-Review/954/10
Total before GPU = $1402 ringgits (used seasonic price so knock off 20 if you get the corsair)
Many Amercians who don't know about power supplies****. Don't buy cooler master power supplies. Go with a Seasonic or Silverstone PSU.
The two versions of windows there, you want the 64bit. If it says 86; it actually means its 32-bit. So don't buy that .
Also your HD 5830 is still an alright card. Not the greatest; but hey. It'll work for now for sure. =). And you'll find it perform a bit better with your new setup.
EDIT: oh and 'Amercians' also = rest of the world. The problem with cooler master power supplies is that they have a lot of mediocre/bad PSU's that have high wattages, like 650-750W. And they're often cheaper than quality 500-600W units. So people see it and go 'HEY, HIGHER NUMBER, CHEAPER PRICE, MUST BUY'. I cannot tell you how many times I've had to correct PSU choices in builds for my local e-tailers facebook page/discussion page for those wanting to build computers...
