- Jan 19, 2001
It has been a long time since i updated myself on water cooling systems. I'm going to build a new system and i have decided that i will get this cooler master casing. (http://www.coolermaster-europe.com/...rial=RC-534&other_title=+RC-534+Centurion 534)
I'm going to be building a Pentium system and intend to overclock it again....as always but am wondering which water cooling system to use.
Question 1: Which would be a better water cooling system?
1. Thermaltake (http://www.thermaltake.com/product/Liguid/DIY/cl-w0075/cl-w0075.asp)
2. Gigabyte (http://tw.giga-byte.com/Products/Cooler/Products_Spec.aspx?ProductID=2125&ProductName=GH-WIU01)
Question 2: With about the same budget, if i get a customized cooling system, what will the parts and brand be assuming i want a standard simple cooling system.
Question 3: Will either cooling system fit into the cooler master casing?
I know i can probably read the threads posted in this forum to get the answer but i do hope somebody can give me a direct answer cos i really don't feel like reading all the hundreds of threads posted to find out. I've been really out of touch with computer systems lately. Any advice is much appreciated. Thank you.
