Stick with an 8XXX series chip. There is not gain to be had by going to a 9XXX chip, they are just a higher binned chip and even at stock demand 1.525v VCore which will over power your AIO cooler. Anything short of a custom loop with either of the 9XXX chips will lead you to nothing but frustration and the need for a custom water loop to run properly.
Pick up one of the 8XXX chip, my choice would be the FX8370 and overclock it as far as your cooling will allow you to do. From there if you want more later you can get into a custom loop and clock it up to what either of the 9XX chips can do.
Agreed!It won't bottleneck a 390x. If you added a second 390x then you may run into some issues as SLI/Xfire doesn't perform as well on AMD as it does on Intel, but that shouldn't be a major difference maker with a single GPU.
I've got my 8350 sitting at 4.8gHz w/1.48v on that AIO and MOBO
Thanks for the replies everyone! I went with the 8370. Now this is my first build in like 5 years so I've been out of the loop with computers for a while. I was doing some reading and a lot of people bash this cpu saying even when over clocked it'll bottleneck the 390x like crazy and others say it won't. Can someone shed some light on this for me? It will be run on Windows 10 and I have a 1080p monitor.
