- Apr 22, 2004
- dutty south
Lifthanger said:I start to get frustrated with this cooling issues.
everything (as5,lapping,slk900,more cfm,duct over cpu) told me it would reduce temps by a few degrees, but if that was true , I'd have -10C.
My arctic copper silent (33cfm) with silicone tim did the same job as the slk900 (45cfm) with as5. this is on idle.. or is it normal that idle temps stay the same?
i understand it can be frustrating but as with anything you should know that results will vary. nothing is consistant all the time. there should be a slight or pretty decent drop in idle but you should really see the drop in load when everything is done right. i dropped 8C going from stock to sp94. dropped 2C from as5, dropped 1C from lapping. all of this is load temps btw. good luck
