ParaThermalZ
- Dec 21, 2015
Tried to overclock my fx 6300 to 4.7ghz. When i turned it back on no monitor connection, no beep. All fans are on the processor even gets hot. Did i kill it?
ParaThermalZ welcome to the forum.
Doubt you killed it, unless you overvolted it. These processors are pretty tough chances are you just tried to push it too far too fast. Overclocking is a process and to do it correctly you need to take your time and have patience. You probably need to clear the cmos to get it to start back up. Once it's back up, post what the components in the Pc are ie. motherboard, ram speed and gb, what heatsink you're using, case, powersupply etc. Then read this guide.
Likely a jumper on your board. Check in your manual for where it is located on the board and how to do it.How would i reset my CMOS?
Already noted.Also... $65 board. 4 Phase, no heatsinks...
Actually that board is a 3+1 Vrm. I can't believe they even list the Fx 6300, 8320e and 8370e as compatible, ridiculous!
ParaThermalZ Do not try and Oc on that motherboard!!!!!!!! You'll be lucky if the board is the only thing that fails, if it does it could kill the Cpu as well. If you really want to overclock, you're going to need a better motherboard and higher end heatsink. If this is the path you want to choose, please ask us for help picking out components.
Ok but just so you know the 1150 socket is EOL so the longer you wait the harder it may be to find a 1150 socket motherboard.I plan on switching to intel in a weeks, i have a pentoum g3258 i just need to get a motherboard, i plan on upgrading to an i5 in about 6 months
Why not hang on to what you have until you get the i5? Some games (like 3/4) wont work with a dual core CPU...
