Set the CPU/NB Offset Voltage to Manual and then enter a value of 1.225. The CPU/NB voltage is a component of the ICM (Integrated memory controller). Overclocking it really enhances memory performance but it needs a little extra electrical "umph" to be overclocked and remain stable.
Set CPU Load Line Calibration to "Enable".
Now, with the present FSB of 210 mhz. run a 20 minute Prime95 blend test. Whenever you run a Prime95 stress test like this, always have HWMonitor already open on the desktop to monitor temps and voltages.
If you pass the test, bump the FSB up to 220 mhz and retest for 20 minutes. Repeat this process of increasing the FSB by 10 mhz increments until you fail the Prime 20 minute test. Failing can take several forms: Blue screen, spontaneous restart, locked system, Prime95 itself freezes or one or more of the four Prime95 core workers drops out.
If you fail the test, go back into bios and increase the CPU Offset voltage by .025 after taking it off Auto. Retest. Pass or fail, post back with attached pics of the three CPU-z tabs and of HWMonitor immediately following the most recent test.
Watch core temps and TMPINx CPU temp lines. We don't want core temps to exceed 55-57c or any of the TMPINx lines the CPU temp to exceed 70c. Stop the test if this occurs or if "CPU vcore" exceeds 1.55 in HWMonitor.
