Mercurious
- Dec 15, 2015
I am assuming that nothing has changed in your set up since your original post. If so, then I think your original consideration was the correct one. It probably has to do with your RAM.
When I hit about 3.6ghz on my overclock my BIOS would boot but at windows boot or shortly thereafter the system would crash. Fixing my RAM handled this and actually noticeably improved my computers speed of operation.
A few things to consider with your RAM are:
1) RAM should be a matched set otherwise you will have more difficulty overclocking it.
2) I have read that these Phenom IIs really don't like anything above a 1600mhz frequency and while it can be done, it is tough. I have not personally tested this yet as I wanted the highest stable CPU clock before I started messing with optimizing/overclocking my RAM from stock. Right now Your RAM is running just a touch over 1600mhz because your FSB is set to 200.67 and you have a 1:4 multiplier. So your actual RAM frequency with these settings is 2x200.67x1:4 = 1605.36mhz Any reason you’re not running a standard base clock of 200? That would give you a RAM frequency of 1600mhz.
3) tRC timing was the crux of my boot problem and I suspect yours as well but, I would suggest checking the other two basics above before messing with timings. tRC timing should be set at tRC = tRAS + CL +/-1. My G. Skill RAM was set to tRC=tRAS+CL. When I boosted it to tRC=tRAS+CL+1 I got clean windows boots and stability. Per your post your tRC is set at tRAS+CL-2.
4) The CPU-NB is the communication link between your RAM and your CPU. I found that I could monitor my CPU vBoost in CPU-Z during Prime95 Blender and if vBoost was greater than +5% I knew the CPU would eventually drop threads and destabilize. If vBoost was greater than +3% but less than +5% I could bump up my CPU-NB voltage a touch at a time and get vBoost to stabilize at or below +3% and that would greatly increase the OC stabilization. If bumping CPU-NB did not lower the vBoost, then I knew to look elsewhere for stability first and then come back and check this point.
What to try first? Depends on what is going on in your BIOS. If you can answer these questions I can give you some thoughts on how to proceed using the above information.
- Is your RAM matched?
- What is the exact model on your G. Skill RAM so I can look up the stock timings?
-In your BIOs, are your timings and frequencies set to auto or manually set? What does BIOS actually say when you look at it as opposed to what is reported by CPU-Z?
-In your BIOS what are your HTT and NB speed settings (auto, manual, if manual what are they set at)?
