- May 23, 2004
- Ohio
Hi, I have a MS-6590 KT6 Delta VIA chipset V2 motherboard with the latest bios 5.7 V flashed . I had a 700 MHz duron CPU and
did an upgrade to a Athlon XP 2700+ 2.167 GHZ, So my problem is the bios only recognizes it as a XP 1500+ 1.3ghz. I cleared
the CMOS no help. How can I use this CPU to its rated specs? op is XP - pro. Any advice will be greatly appreciated.
HammerHeadHank
HammerHeadHank
