Hello there everyone;
I'm in some need of help; I am going to water-cool my pc but need some guidance on what to buy, my pc specs are;
-CPU - I5 3570 3.4GHZ
-Graphics Card - GTX 680
-Motherboard - ASUS P8Z77-VPro
-Ram - Corsair 1600 Ram
I think thats all, I am only watercooling my CPU And Graphics Card and have looked up a few diffrent componants;
-CPU - EK-Supreme LTX - Acetal+Nickel CSQ Intel CPU Waterblock
-Graphics - Koolance VID-NX680 Water Block
-Radiator - Phobya G-Changer 280 Radiator [338x145x60mm]
-Fans - 2x 140mm BitFenix Spectre Pro
-Reservoir - Bitspower Z-Multi 250mm Water Tank
-Pump - Still Need One
-Tubing - Still Need Some - Green
-Liquid - Pure Distilled Water
-Fittings - Still Need Some
This is what I had in mind (But can still be changed if its a bad setup or what?), I am not sure where to go and I need help to try and make sure it would all fit together as I have made sure it will fit in my case so far as I have plenty of room.
All help Is much appreciated and I look forward to hearing back,
Thank You!
Thank You!
