- May 6, 2011
- Medford OR
using AMD Overdrive it shows me the CPU temp
and its the same temps at idle from when before i unlocked cores 3 and 4
i'm just gonna get a fan controller i found off newegg that has temp probes on it...
however, i'm unsure as to where they go, and they thin enough to go between the CPU heatspreader and the HS without loosing the heat transfer rate?
This is the controller i'm going for:
Here at Newegg
Here at Newegg
