Hi! This is my first post on overclocks.com and I'm seeking advices / opinions for the new computer I am planning to build at the end of May.
I know I could wait a bit for the AM2 socket or the Conroe from Intel but I'm no sure it's worth the wait. I would prefer buying a very good system now and change almost everything in 3 years.
I want to overclock it on air so I tried to choose every parts according to that. I'm selling my old computer so I wont be taking parts from it. I made a lot of research for the parts but I need a second opinion!
Processor:
AMD ATHLON 64 X2 3800+ 939 MANCESTER OR
AMD ATHLON 64 X2 4400+ 939 TOLEDO
Which is better for overclocking? I wanted to go with the FX but it is way to expensive and I can't get a Optie 165
Heatsink:
THERMALRIGHT XP-120 with Panaflo 120 mm 2500RPM 104CFM 41.5DBA
Is their something better below 100$
Case:
THERMALTAKE Soprano
I don't want to spend to much on a case and this one come with 2X120mm fan and 1X92mm fan.
Memory:
OCZ OCZ4002048ELDCPE-K 2Gb EL DDR PC3200 PLATINUM SERIES DC KIT (CL 2-3-2-5 ) OR
OCZ OCZ5002048ELGEGXT-K 2Gb EL DDR PC-4000 GOLD SERIES GAMERS eXtreme DC KIT (3-4-3)
I think the platinum would be better for overclocking?
Motherboard:
DFI LP UT NF4 ULTRA-D
Video Card:
SAPPHIRE ATI Radeon X1900XT PCI-E 512MB DDR3
Hard Drive:
2 X SEAGATE 160GB BARRACUDA 7200.9 SATA-II 3.5LP 8.5MS 7200RPM 8MB 3GB/S in RAID 0
Power Supply:
OCZ POWERSTREAM 520 Watt Power Stream SLI
I would have prefer a powersupply with a 120mm fan and modular connectors. Any suggestion?
DVD Drive:
NEC DVD+-RW ND-3550A 16x Dual layer Black
Monitor:
DELL - UltraSharp 2005FPW 20.1-inch Wide Aspect Flat Panel LCD
Did I forget something? Any comments, opinions, suggestions?
Thank you,
Ben
Processor:
Heatsink:
Case:
THERMALTAKE Soprano
Memory:
Motherboard:
Video Card:
Hard Drive:
Power Supply:
DVD Drive:
Monitor:
Thank you,
Ben
