- Jun 23, 2012
Long story short I'M DONE! I'm tired of my Sabertooth 990FX, it's gotta be replaced ASAP. I won't describe all its problems I do not want advice on fixing it i'm sorry, just warning you DO NOT GET this board. It is horrible, unstable, and inconsistent. Wasted $189.00 now. I will NOT RMA it, I'm going to blow it to pieces with my shotgun I think. I know the current power pull of my CPU is very high. I'm willing to spend $150 on a new MoBo. Is there a stable, non-ASUS and suitable replacement?
MoBo that is being replaced:
ASUS Sabertooth 990FX AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736
Here is what I have currently:
CORSAIR Professional Series HX1050 1050W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS SILVER Certified Semi ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139034
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CML8GX3M2A1866C9R
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233240
LITE-ON Black Internal 12x BD Combo SATA Model iHES212-08 LightScribe Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106451
AMD FX-8120 Zambezi 3.1GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8120FRGUBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103961
XFX Double D HD-695X-CDFC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150549
Western Digital Caviar Black WD1502FAEX 1.5TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236117
