- Dec 21, 2011
- Republic of Texas
You might be able to use some sort of SLI fitting. Maybe a bitspower crystal link with some angle adaptors, or one of those expandable koolance ones with some angle adaptors.
NO you actually need 90 degrees rotary and a SLI bridge connector (extenders will not work since if you screw in one side it will un screww in the other.I was thinking about using this
and this
do you think it will work?
