i want to build new computer so here is the list on my mind can you help me if it's good and compatible.
case:
Corsair Obsidian Series 800D CC800DW Black Aluminum / Steel ATX Full Tower Computer Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001&Tpk=corsair obsidian 800d
mobo:
ASUS Rampage IV Formula LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131808
cpu:
Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73930K http://www.newegg.com/Product/Product.aspx?Item=N82E16819116492
gpu:
2x EVGA 02G-P4-2689-KR GeForce GTX 680 Hydro Copper 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130772
psu:
CORSAIR Professional Series Gold AX1200 (CMPSU-1200AX) 1200W ATX12V v2.31 / EPS12V v2.92 SLI Certified 80 PLUS GOLD Certified Full Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139014
memory:
G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9Q-16GBRL http://www.newegg.com/Product/Product.aspx?Item=N82E16820231315
storage:
Intel 520 Series Cherryville SSDSC2CW240A3K5 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD) http://www.newegg.com/Product/Product.aspx?Item=N82E16820167086
Western Digital Caviar Blue WD3200AAKX 320GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136770
water cooling:
pump:
Swiftech MCP655™ 12v Water Pump w/ Speed Control and 3/8" Conversion Kit (317 GPH) http://www.frozencpu.com/products/6...ed_Control_and_38_Conversion_Kit_317_GPH.html
top:
EK D5 X-Top Acetal Pump Top Rev. 2 - Laing D5 & Swiftech MCP-650/655http://www.frozencpu.com/products/7...Rev_2_-_Laing_D5_and_Swiftech_MCP-650655.html
rad:
Black Ice SR1 Low Air Flow Optimized - 360 Radiator - Black http://www.frozencpu.com/products/9...ir_Flow_Optimized_-_360_Radiator_-_Black.html
res:
Bitspower Water Tank Z-Multi 150 Inline Reservoir - Ice Black (BP-WTZM150P-IBKBK) http://www.frozencpu.com/products/1..._Reservoir_-_Ice_Black_BP-WTZM150P-IBKBK.html
tubing:
Danger Den DreamFlex Value Pack - Tubing / Clamps / Tube Cutter ( 1/2"ID x 3/4"OD ) - Clear UV http://www.frozencpu.com/products/1...lamps_Tube_Cutter_12ID_x_34OD_-_Clear_UV.html
cpu block:
EK Supreme HF Universal CPU Liquid Cooling Block w/ LGA 2011 Hardware - Rev 3 - Acetal + Electroless Nickel Plated (EK-Supreme HF - Acetal+EN (Nickel)) http://www.frozencpu.com/products/1...l_Plated_EK-Supreme_HF_-_AcetalEN_Nickel.html
fittings:
14x Bitspower Ultimate G 1/4 Thread 1/2" ID x 3/4" OD Compression Fitting (BP-CPF-CC5) http://www.frozencpu.com/products/8...D_x_34_OD_Compression_Fitting_BP-CPF-CC5.html
2x Bitspower G 1/4" Thread 90 Degree Rotary Fitting Adapter (BP-90R2) http://www.frozencpu.com/products/8...90_Degree_Rotary_Fitting_Adapter_BP-90R2.html
quick disconnect:
Koolance QDC (Extreme Flow) No-Spill, Female Compression (13mm, 1/2" x 19mm, 3/4")(VL4N-F13-19S) http://www.frozencpu.com/products/1...ompression_13mm_12_x_19mm_34VL4N-F13-19S.html
Koolance QDC (Extreme Flow) No-Spill, Male Compression (13mm, 1/2" x 19mm, 3/4")(VL4N-M13-19S) http://www.frozencpu.com/products/1...ompression_13mm_12_x_19mm_34VL4N-M13-19S.html
coolant:
3x Fluid XP+ Extreme Non-Conductive 32 oz. Liquid Cooling Fluid - Blood Red http://www.frozencpu.com/products/1...e_32_oz_Liquid_Cooling_Fluid_-_Blood_Red.html
rad fan:
3x Phobya 120mm x 25mm Nano-2G 1500rpm PWM Fan - Red LED http://www.frozencpu.com/products/1...x_25mm_Nano-2G_1500rpm_PWM_Fan_-_Red_LED.html
question:
1. does 1 360 rad will enough to cool cpu (oc'd to 4.2ghz-4.4ghz) + 2 gpu (stock speed)
2. do you think the 1200w psu is overkill? or can i change it to 850w
3. does all my part are compatible? the fittings, mobo, cpu, tubing and other parts.
case:
mobo:
cpu:
gpu:
psu:
memory:
storage:
water cooling:
pump:
top:
rad:
res:
tubing:
cpu block:
fittings:
quick disconnect:
coolant:
rad fan:
question:
