- Jan 13, 2005
interesting route he has there. the lowest tube...where does it go? where is the fill port?
I'm thinking of getting a different reservoir. Some kind of dual bay reservoir I can attach my pump to. I have 2 empty slots at the front for the room. I have a MCP-350 pump. Any good ones out there with a slow indicator or some cool factor?
http://www.xoxide.com/swiftech-maelstrom51-4-dualbayreservoir-standalone.html
Any thoughts on the Maelstrom 5 1/4" Dual Bay Reservoir. I like the look. Temp on front, pump mounted under it.
GTXJackBauer, That is an impressive reservoir!
Maelstorm is nice because it comes with in a built-in water temp and display but is a bad design when running the pump(s) at full speed as air will get sucked back into the loop and not good for the pump(s) either. If you fill it up to the tee, than you can run it at full load but eventually it will start sucking in air. I know this because I own a Maestrom 35X2.
I'd like to read more about it's sucking in the air. Do you have a link I can read about it more?
Anti-vortex/anti-bubbles system
A tube surrounding the pump inlet features various size openings in its wall and prevents the formation of a vortex, and air entrainment in the loop
An open-cell sponge further traps micro-bubbles before their can re-enter the inlet
Although it probably does not matter for 99.9% of the users as they would never need to run dual pumps at 100% throttle...
GTXJackBauer, Turned the Dual D5s down to 4 from 5. Quieter and no noticeable change in temps. When I had a MO RA3 420 Pro external rad I liked to keep the flow rate higher (had the Koolance QD4 quick releases that add a bit of resistance).
Since my new build has very little resistance, just 3 rads, 1 cpu block and 2 gpu blocks the reduced flow rate is quieter. Besides, my D5s are in series and Martinsliquidlabs.org did a great article on flow rate when running in series.
