Hi guys,
New to the forum here. Also, new to WC. This is my first project. I bought the H20 220 Apex Ultima plus.
Computer is
i7 920
Asus P6T Deluxe
6 gig Corsiar Dominator
Geforce 260
I am not going to buy the full mosfet/nb sb plates for the loop. It is cost prohibitive for blocks i can only use on this motherboard.
So basically the way I see it I have 3 options.
1. Take the fins off of the NB and apply my MCW30 directly to the copper of the pre existing heat sinks
2. Put a fan on the fins and forego the WC on the chipset
3. Remove the whole fins/heatsink assembly, WC the NB and try and get enough Swiftech MC21 mosfet coolers to passively cool the SB and the other MB chips.
Either of the first 2 is preferable for me. If I can reach a stable 4ghz OC and my chipset be in no danger then I am happy regardless.
So..... What do you think? Which method is going to work better? Discuss away and if anyone has experience with this situation I would be very grateful for your knowledge.
Thanks,
Stefan
Computer is
i7 920
Asus P6T Deluxe
Geforce 260
Thanks,
Stefan
