Ok i posted previously in a different name (on my brothers pc) and TT120 replied so i though you all might want to know as well as TT120.
TT120 Quote,
"It is generally thought that anything AXIA and later will be good for overclocking. You have the first BXIA I have ever heard about. The BXIA is a later stepping revision and so "should" be a good clocker. I, as well as many here, would be very interested in knowing how far you can get that chip to go. BTW, when and where did you get that chip?"
Heres the details on the CPU:
A1200AMS3B
BXIA 0112CPCW
Y6170640284
Ok first off i got this CPU at a computer fair at Blackpool UK on Sunday 22nd April 2001 and the trade stall it was from is under the name AA Computer Centre LTD. The address is 18 - 24 knowsley street, Cheetham hill, Manchester M8 8HQ.
Tel: 0161 835 9434
Fax: 0161 835 9433
Heres my system specs:
1.2Ghz (200fsb) BXIA Athlon @ 1300 (104x12.5)
CB5 5G12 Coolermaster fan (only rated up to 1.2 ) (Whats this fan like anyone please? And what fan do you all recomend for total cool air flow?
ATX E-Star Nokia case with 1 case fan connector (fan coming soon)
ABIT KT7A RAID - Standard BIOS with 4 way interleaving, CPU drive strength 3, Enhance chip performance enabled.
Hercules 3D Prophet 2 GTS 64 (0635, latest Detonater drivers)
30.7gig HD IBM Deskstar 75GXP 7200RPM ATA100
256meg PC133 Micron 16x(16mx8) SDRAM (CL 3 up to 133mhz) (CL2 up to 100mhz)
Windows 98
Soundblaster Live Platinum!
"SiSoft Sandra reports a Revision/stepping 4/2 (dont know if this is important but...)"
Now im fairly new to OC'ing so if any of you have any ideas or sugestions then please let me know, even better if you have a 1.2 Athlon and have Over Clocked it fairly well let us know your BIOS settings, multiplier, fsb, voltage etc and i will try it out on my BXIA chip.
Interestingly my CPU is at 104x12.5 and to get 104fsb i set my bios to 100x12.5 and the computer/bios booted up showing 1300 104x12.5. There is no way of setting it up for a 104fsb in the bios so why did this happen?
Ok then i managed to get the cpu up to 1400 140@10x (default voltage) and it reported it in the boot up process but just as windows was finishing to load up it comes back with the error "Its now safe to turn your computer off". I did not try to take it further as i dont think it will go much more on my current setup and/or configuration. I think the cpu could handle 1400 no problem with better cooling and/or modifying a few settings. Also i not sure about setting up voltage settings at the moment as im not that informed on the process.
I also tried it a few settings just below 1400 and i got various error messages and windows protection error reports etc.
Then i tried a few setting on a high fsb140/145 and the computer would not load up so i had to switch on and off about ten times to get into the bios and reset my CPU settings.
Now i moved it down a little 1375 [email protected] (default voltage) but it was a bit unstable.
Then 1350 [email protected] (default voltage) this was very stable until about 2 hours later when it rebooted itself from windows. :-D I think with better cooling the chip would be very stable at this setting. 1320 110@12x (default voltage) was also stable but i am not happy enough with my cooling so 1300 it will stay for now.
Ok then, i think the fact that this chip is on a 200mhz fsb is stopping it OC'ing in the high fsb but it is it still very good for OC in the lower fsb. I wish i had a 266fsb BXIA to try it out with.
Overall i think this chip is very Over Clockable and with better cooling this chip could easily handle 1400/1500 from air cooling alone, and as for you lucky people out there with a water cooled based system, well i'll let you do the sums... ;D
Anyhow thats it for now so let us know any ideas or sugestions you might have and i will try them out.
All the best.
DJ WATTS
TT120 Quote,
A1200AMS3B
BXIA 0112CPCW
Y6170640284
Tel: 0161 835 9434
Fax: 0161 835 9433
Windows 98
All the best.
DJ WATTS
