trents, JEDEC is read wrong is CPU-Z. I believe I already told someone around here this before.
I hope you realize there is no 685 MHz option in your BIOS.
Please look at the XMP profile instead. The OP is running a mild overclock on DRAM. Most likely fine.
HT Link is fine. 10x multi. If he wants to lower it, that's cool, but won't change anything. Nothing wrong with running 2700 HT Link, but it is useless.
Core voltage is fine. 1.375v is probably the stock voltage, if it is a low-leakage CPU. Anyway, 1.375v is most likely stable on a 3.65 GHz overclock.
All DDR3 can run 1T command timings save for Crucial Ballistix 4 GB density sticks, which contain Micron D9 PFJ ICs. Those can only run 1T to about 2000 MHz. Anyway, 1T is faster.
