Alright, so I usually try to fix stuff by myself before asking for help but I gotta admit I don't know what to do at this point.
This is my current build: https://pcpartpicker.com/user/equifox17/saved/VMcxrH
Running a custom watercooling loop which is basically RES -> PUMP -> RAD 1 -> GPU -> RAD 2 -> CPU -> RES
I didn't touch the BIOS at all, everything is stock, even my 3200 RAM is running at 2166.
So when I boot up Win 10 and check temps, GPU idle temp is 24-25 degrees and CPU idle temp at around 33-35.
Now when I put load on the GPU at 100% i will read max 35-38 degrees, but the CPU in realbenchmark will sky high to 80-95 degrees in no time as soon as it get to video encoding. It will begin to throttle. I tried to reseat my waterblock but Evo Supremacy are kind of noob proof on that side. Also replied thermal paste different times, made sure there was no air in my loop as well (GPU temp would be affected anywaya)
I'm out of option, I tried pushing real hard on my waterblock while stressing the CPU to see if it makes any difference, nope. Might it be a bad luck and should RMA the CPU ? Cause I'm getting real tired of this and this computer is used for some casual gaming but mainly for programming and in its current state I can't use it for work.
Thanks for your help !
