You can ignore the ones that you've already answered elsewhere in this thread:
- What are you planning to do with this compuer? Please be as specfic as possible.
-Gaming
-Rendering/Video Editing
- What is your budget?
1500$~2000$ including the monitor.
- Does this include a copy of Windows?
No, I already have it.
- Does this include peripheals (a keyboard, monitor, mouse, speakers, etc.)?
No, I already have them.
- Are you from the United States or a different country? Are you ordering from your own country or from across borders?
I am from a different country and I'll be ordering from Amazon.
- Wherever you may be from, does the store that you are planning to order from have a website? It's okay if it isn't in English, we can manage.
- If you are from the United States, do you live nearby a Microcenter?
- Do you have any specific requests with the build?
No
- Do you plan on overclocking? If yes, do you have a specific goal in mind?
Only minor CPU/GPU overclocking and not right away, it might take some time to actually do it.
- Would you prefer the build to be particularly small?
Mid-tower is enough for me, like the NZXT Phantom 410
- Would you prefer the build to be particularly quiet?
Well, you can't get rid of the noise while completely utilizing the CPU/GPU.
- In general, do you prefer this to be a computer that you can spend money on now and let it rest, or a box built for continuous upgrading?
Of course, continuous upgrading, maybe every 1~2 years.
- Do you ever plan on utilizing NVIDIA's SLI or AMD's CrossfireX technologies? These features, with a compatible motherboard, allow a user to link multiple identical graphic cards together for added performance. In real world terms, this lets you buy a second identical graphics card down the line as a relatively cheap and easy way to gain a fairly large boost in performance. However, this requires buying a SLI/CFX compatible motherboard and PSU now, which may result in slightly higher initial cost.
Yes, I am planning to SLI. Dual OC GTX680's is what I have in mind.
Once again, thank you in advance for taking the time to answer these, and I hope you enjoy your stay at OCF!
