- May 1, 2004
- Bronx,newyork
Hi there!
I'm looking at building a new PC For myself this time with overclocking in mind, mild overlocking. Nothing to extreme However, I have mountain of student loans to pay off and I'm thinking whether or not I will go there. I probably won't upgrade my stock cooler, until a few months from now. I don't mind going budget, as I see newer cpu's aren't going to overclock as much as they use to. Mind you I'm coming from a Q6600, and anything is going to be faster than this.
Since I have microcenter near me I plan to pick i7-4790K. If my Budget does not hold I'll stick with i5-4690K. I have 40 dollars off a motherboard if I buy them together and my motherboard of choice right now is the ASrock extreme 6. What do you guys think of this choice? I'm a die hard Asus fan, but I hear good things about this board. I assume they are stable enough these days?
I only play warcraft 3 currently, so on board graphics will serve me just fine. If anything in the future, I probably will only get a single graphics card. I don't think I'll ever have the need of SLI/Crossfire. What is more important to me is good onboard sound.
~thoughts~
Probably the I5 will be just fine for me, but I may take on the extra horse power because I sometimes do MATLAB simulations. I may even go down to an I3 if I see my budget won't allow it. So I guess my question here is, Which high end config would you guys pick, I7+motherboard for overclocking, or low end i3 with no overclocking.
Side-questions, Intel's roadmap is confusing me, are they planning on sticking with the new 2011 V3 socket, or is that just for their higher end enthusiast boards? I.e is this last refresh, Devils Canyon, the last they will do on the 1150 socket? Or is that impossible to tell at this point.
Thank you all in advance
Imposter
~thoughts~
Imposter
