Hi guys,
First post here, although I've read and read and read posts on the forum, trying to get as much info as I could to try my hands at overclocking my new setup:
Phenom X2 560 Black Ed
4gb G.Skill Ripjaw F3-10666CL7D-4GBRH
Asus M4A89GTD PRO/USB3
Hyper 212+ air cooler
Anyways, I collected a lot of info from a number of forum posts here and I think I have found stable settings, I just want to make sure I did everything right.
I should start by saying that what initially pushed me toward overclocking is Microsft's FSX. TO achieve decent framerate in this sim, you need a fast CPU.
So I thought, the B60 is apparently an excellent candidate for overclocking, let's give it a shot. Then through all my posts readings and BIOS play time, I realized, damn, this overclocking thing is a hobby in itself, and I haven't flown once in FSX since then
Anyways, to the good stuff;
First thing I did, I unlocked the B60 2 hidden cores successfully, ran Prime95 on stock settings (BIOS all set to AUTO) overnight, no crash. So the nice little X2 560 is now a [email protected] stock, not bad for a 89$ chip!
Then, I set my RAM in the BIOS to official G.Skill tech guy recommended settings(http://gskill.us/forum/showpost.php?p=19131&postcount=2). Ran some more Prime95 Blend, everything still stable @ stock/auto settings.
Then I started fiddling with the CPU overclocking. I'm a complete beginner so I decided to take the easy "multiplier/no fsb" route. I increased the multiplier by .5 and monitored how the BIOS AUTO settings adjusted the vcore each time, then booted and ran P95 for a while.
Here's what I found:
@3.3ghz x16.5 1.248v (stock settings, AUTO BIOS) stable
@3.5ghz x17.5 1.284v (AUTO BIOS) stable
@3.7ghz x18.5 1.332v (AUTO BIOS) stable
@3.8ghz x19.0 1.332v (AUTO BIOS) OS boot BSOD
@3.9ghz x19.5 1.332v (AUTO BIOS) no boot
@4.0ghz x20.0 1.332v (AUTO BIOS) no boot
Interest thing, the motherboard auto settings did not adjust the vcore to more than 1.332v between x18.5 and x20.0, but at least I had an idea of the CPU limit.
Next, I increased the vcore a little bit, trying x19.0 first, since this is where I got my first crash. I went with these settings:
@3.8ghz x19.0 1.35v
Ran prime a couple hours and was stable with a CPU temp of 45c
Then I tried the following settings:
@3.9ghz x19.5 1.375v - Unstable/P95 temp 47c
@3.9ghz x19.5 1.400v - Stable P95 temp 48c
@4.0ghz x20.0 1.400v - Unstable/P95 temp 48c
@4.0ghz x20.0 1.450v - Stable/P95 temp 50c (Voltage reading=1.476v, P95 still running, 4 hours so far...)
So, do you guys see anything wrong with my findings/settings? So far, looks like I'm pretty lucky , P95 has been running for 4 hours (FFT test) with 4 cores@4ghz
Now, couple questions:
According to the AMD specs for the 560, the voltage range is between 0.875 and 1.400v. I'm currently running at 1.450v in BIOS but reading in CPU-Z is 1.476v, which is 0.076v over the limit, is that a problem?
Regarding Prime95 stress test, which one is best for stability testing. I've tried both blend and FFT but it seems that FFT is best for CPU testing, am I right?
While Prime95 is running, I see my 4 cores @100% usage, but the computer is still responsive as if nothing was running in the background, normal?
Can I still use my computer during the stress test without interfering with Prime95 tests?
I guess that's it for now, thanks all for reading and commenting, please let me know if I'm totally off with my setup or if it looks safe enough.
Cheers!
/iam
@3.8ghz x19.0 1.35v
Cheers!
/iam
