- Thread Starter
- #21
The big question ........ do you plan on keeping this system long term or going with a different direction all together? Follow that up with do you plan or think you may like to Overclock beyond 4.5GHZ in the future?
That is a GREAT question bassnut, I think maybe a wise choice right now is to use the Asus M5A99FX PRO R2.0 for now with a better cooler. This would get me up and going to around that 4.5ghz, and maybe run this for a while until new CPU's come out from AMD/Intel
Otherwise the Asus board RGone has mentioned will work fine up to that 4.5GHZ ish area where we see the best performance increase without dealing with that massive CPU voltage jump and the heat that comes along with it. The only real disadvantage to Overclocking these FX CPU is the heat they create you will have to deal with that. One thing for certain if you decide you want to overclock even to that 4.5GHZ you will need some good cooling either an AOI like a corsair H100 or top a top end air cooler to purchase along with the board.
Rgone suggested a Cooler Master 212 EVO (about $35) That sounds like around $150 more I can get this rig running pretty well, certainly better than my old dual core pentium from 2002
If you think you will want to go beyond that 4.5GHZ and chase the big numbers then start planning on big cooling, think custom water cooling. Careful this hobby can be addictive and once you get bit also expensive chasing those big numbers. Either way you decide and there will be someone here that can help you make some good decisions on the parts you buy so you don't spend money on parts you don't need or are not good for the build.
Now THIS could be a problem, I do have an addictive personality. Good news is it seems like I have found a REALLY great group of helpful guys here
I upgraded my PSU to the Corsair CX750M you see below. It has plenty of power, but I bought it a Best Buy while in my ignorance and I don't want anymore problems, and PSU's are fairly cheap. Should I upgrade this?
