- Jan 9, 2002
One major issue I have had is Win 10 auto updates. Anyone got a good link to a workaround for this?
Do you not want to have folding start on startup?
Greetings. Now that it's getting cold outside, I've cranked up my heater; the one with 3 x GTX1080 in it. At some point I'll need to finish installing my custom water cooling loop so I can put a 4th 1080 in, but that's for really cold nights.
BTW, does this team also participate in BOINC, including their team contests?
After dragging my feet I've added my 3970X to the team.
I have an APC 1350 supplying the power needs to my system, and when I added my VEGA 64 to the mix it's alarm tripped w/ in 10 seconds LMAO... I guess a 3970X and VEGA 64 on full blast isn't going to happen right now hahahaha
365716 is impressive for a CPU on just 32 cores, my 4P with 64 cores comes close to that at about 250k +/-, have you opened it up with 64 threads?
Sweet. Did it default to 32 or did you set it that way? Using the SMT threads would bump it up a bit further, but not by a huge amount (maybe 20%).
600k on a CPU!?
That's 1070ti territory...
Your flying up the ranksIt shows the default maximum of 32
I turned on my VEGA 64 and it was getting 1,100,000 PPD vs the 600,000 PPD of the 3970X
It always defaults to 32, set it at 64 and see what is does.
it says 32 is the max...
Did you try and set it to 64? That CPU has 32 cores/64 threads.
yeah it wants to stay at -1 and then shows that 32 is the maximum.
In the end, w/ my VEGA 64 and manually setting it to 16 cores w/ the slider on full i'm doing about 1,500,000 PPD w/ the 3970X doing 230w and the VEGA64 doing 210w, plus the monitors and a few other things my UPS says I'm sucking 775w so that's enough when it maxes out at 810w lol.
SMT Mode
Allows you to enable or disable the CPU Simultaneous Multi-Threading technology. (Default: Auto)
After some research this will only go to 32. Apparently others with older threadrippers use the max of 32 for Folding@Home and then use another 32 threads for Rosetta to get 100% CPU usage.
Yes those arrows let you select more than 32 threads but when you try to save that it just errors out prompting that 32 threads is the maximum. When I'm rendering or doing a blender benchmark all 64 threads are used so it's just the limitations of Folding@home.
You right but, I'm using 7.1.52 and it lets me use all 64 cores on my 4P server boards on 1 CPU slot. I installed 7.4.4 and it only let me use 32 for 1 CPU slot, so you could make 2 CPU slots with 32 cores and see what it does.
