- Mar 5, 2006
- Canberra, Australia
i have the same stepping as you, only its a 175 not 165. My stock load temps are ~43c. running at 2.8ghz on stock volts it reaches ~50 and at 3.0Ghz on 1.525v its hit 60 in a few seconds. 60 is my absolute limit, but it should be safe to go higher theoretically.
This stepping is good. You should reach 2.8 or so on stock volts or close to, but you will find that voltage increase after that is pritty dramatic. Like i said, 2.8 on 1.35v is stable, but 3.0 (only 200mhz more) is not stable at 1.525v!
