regarding the shutdown/power issue, is your bios on the latest version?
And this only happens sometimes?
Thanks for the suggestion, yes, I have enabled global v-sync in Nvidia control panel. It is strange how Shadowplay or the occasional alt-tab temporarily makes it go away. This issue is something that I will just have to live with, I have to draw the line somewhere.Did you enable global adaptive v-sync in the 970? That monitor does not support FreeSync or G-Sync. I don't have a video card but someone said this helps with fps issues on that monitor (I use one myself).
I have tried all of them, though that was an excellent tip. Some have found adjusting those exact screen settings very helpful when it comes to refresh rate problems in older versions of wow. I suppose the good news is that the fps fluctuation along with the shutdown issue occur some of the time rather than all the time, and don't detract a whole lot from my experience, at least considering the current usage of this computer.do you have WOW running in full screen, windowed, or borderless window?
Have you tried compatibility mode ? if memory serves up to cataclysm WoW was... iffy... about using windowed fullscreen/borderless, regular windowed worked well enough but had much more CPU overhead.
It is alright, there is no problem with the CPU, I have monitored it with task manager and RealTemp. Temperatures (and clock speeds for that matter) are fine. Classic is somewhat CPU-intensive, but not as intensive as the newest expansion(s).sorry we couldn't come up with a solution for you.
One last thing to try, would be to make sure that your CPU is pegged at it's max speed and not using any power saving features, maybe it is bopping up and down to idle speeds and causing fps fluctuations. WoW IIRC is/was very cpu-intensive and if the cpu speeds are fluctuating it could be causing a problem.
Also, you may want to update your signature
