Mandrake4565 told it just about like it is and what I am going to write is just to sort of fill in any blanks.
Forum Overclocking : Water Cooling [Solved] COOLER MASTER Seidon 120M vs Corsair H60 vs Antec Kuhler 620
I don't have to have a full-blown review to see the general, overall direction of some component or system. These are just plain everyday users responding to a question about the mini-closed loop cooling systems and how they don't really seem to do much better at all compared to a well engineered high end air cooling solution.
CM Seidon 120M is just not much of a cooler. NOT if you want to push a 6 core or 8 core FX processor.
Is it a Contender?
In that fairly long thread I was testing an Asrock Fatal1ty 990FX Professional motherboard to see if it could begin to measure up to my CHV motherboard in pushing a Vishera based CPU. It did pretty doggone good. I would surely buy it over the Gigabyte UD3 based motherboards.
But the thing I found off-putting was the amount of Vcore the FX-6300 needed to run fast. I was using a borrowed FX-6300 which was one of three a friend of mine had. He had tested all three of the FX-6300s he had and all on good CHV motherboards and all three tested the same to him. To me that means everyone of his FX-6300s needs a lot of VCore to run fast. Well a 'lot' of Vcore translates to a lot of heat. That did not bother him much as he had a 3 fan radiator system and not a cheap mini-water loop system that has little reserve to push a late model FX type processor.
So you are where you are speed wise and likely you will not go further with your cooling and the way that UD3 motherboard works its' LLC circuit. By logical and methodical trial and error you may reach greater than 4.4Ghz stable in Prime95 Blend mode but it will take you trying many options in the bios. And the major change most likely will be in the amount of Vcore you push to and thru the processor and the result of that will be HEAT your mini-water loop will not be able to handle.
Sadly or realistically there are limits to just about everything. In the case of your configuration being able to really push an FX processor, you are likely at the end. Change the system configuration and you can likely go faster as I did with an FX-6300 but at what cost? The cost probably makes no sense just to increase the cpu speed by 200Mhz. It would likely take a more friendly overclocking motherboard and at least in round numbers about a $250 to $300 cooling system. I just don't see that being a good return on investment.
My super cooling is at least 7 years old and hand-configured by myself to really cool on water when I was part of a benchmarking team. It has the beans and brawn to cool an FX processor, by and large the mini-water coolers don't have that much brawn or power. That is about where you are.
RGone...
