- May 30, 2004
Col_Loki said:Well if prime95 ran for 24hours then your CPU / FSB / RAM / COOLING / PSU is pretty much rock solid and you have nothing to worry about. If one of them is dodgy or over stressed then Prime95 will root it out for you .
Buggy software, weve all had it and you will find once windows has had one "windows has recovered from a critical error" it will throw up alot more just for the crack.......
Anyway looks like your fine to start overclocking............ read the guides and know what to watch. Good Luck anyway.
That's not always true in my experience. Windows XP and Windows 2000 are more likely to crash with an unstable overclock than Windows 98, because Windows XP and Windows 2000 seem to stress the system more than Windows 98 when doing the same things. Also, I made a list of stability problem severity stages:
1. Prime95 fails
2. Windows crashes when running a lot of things
3. Windows crashes randomly when idle and you may get application crashes with small applications.
4. Can't even install Windows, because the Windows installation process will fail.
5. POST failure.
