- Mar 12, 2002
Ok so I noted before I purchased these that one other user here on these forums had reported a potential problem with the new nylon D5 dual bay reservoir that XSPC has put out. I almost avoided purchasing them, but they fit my stylistic preferences, and I got them combo deal with the pumps from PPCs.
So I ordered three of these units and installed them right away, no issues to report and they are even quieter than I expected they would be!
Now flash forward 6 weeks later. One of the two units has a minor leak which I conclude could be an improperly tightened fitting or something along those lines, so I break it down, clean it, check all my fittings, and replace some of the tubing.
All seems ok but 30 mins after I get it installed its leaking again..... So I pull it down again dry it out overnight, add silicone to anywhere that looks like it could potentially leak and seal it all back up again. Two days later the leaking reappears.
At this point Im fairly certain that the leak is coming from below the top plate and the reservoir body; Just above where the outlet is.
At this point I have now spent a grand total of 10-20 hours of unnecessary labor trying to make this reservoir usable and its not going to happen. I have contacted XSPC directly to see if they have an answer for me, but if they offer anything less than a replacement for me its not going to be a pretty day.
I would caution anyone who is considering buying one of these reservoirs to look at other options, as this apears to be a fairly common problem among these units.
I also dredged up another thread from a few months back where another user reported the same issues HERE
Below is the short message I have sent the for initial contact.
Hello, I currently own 3 of your newer model D5 Dual Bay Reservoirs. However, I am having problems with one of them. This particular res started leaking five or six weeks after installing it. Of course I took this to be user error and have replaced the tubing and fittings attached to the reservoir. After reinstalling and discovering that the leak is still persistent I removed it and added silicone to each of the exposed edges except for the pump clamp ring area. This worked well for a few days but the reservoir has begun leaking again.
Based on my observations the leak appears to be coming from between the top plate and the reservoir body. At this point I would request a replacement unit.
