- May 30, 2004
- Folding@Home
Load says 0...He must be using smoke and mirrors..Are you kidding me?!?!?!? 35C under load??? That can't be right...
If CPU-Z is right... that's some hefty voltage you're running there Tim. I'm, personally, not going to go over 1.35v under load. Bios and idle may be a little higher.
I've heard those auto turbo OCs run the voltage up higher than it needs to be. You should go back and tweak things some more and either go for a higher OC or lower voltages
Yes, I had read a couple reviews where >1.35v was risky, but hadn't noticed that my CPU-Z voltage was scary, until youze guys mentioned it.
I disabled "turbo" and set the multi manually to 42, memory to 1.5v, and CPU volts to 1.35v, with a +0.005v offset; Windows wouldn't boot without the offset. CPUZ is actually showing 1.36v ATM. Temps are real acceptable, below mid 60s C.
Question about -bigadv..
Could me using 2 GPUs be the cause on me not getting bigadv?
Are the GPUs using to much of the CPU for bigadv to work?
Nope... the assignment server only cares about the availability of 8-cores and enough memory (I think it's ~3000MB).
Nope... however, running GPUs can/will negatively impact the performance of the SMP client. When I run bigadv on my i7s I use the following to start my client (your exe name may be different):
fah.exe -smp 7 -bigadv -verbosity 9
Note the 7 behind the -smp flag. This will ensure the SMP core process only runs 7 threads of the 8 available, leaving one thread for GPUs to work with. At your OC (4GHz) you can easily do this and still make the deadlines on the work units. One less thread really doesn't impact the SMP client performance that badly. In fact, in my experience, it's better than making both clients jockey for time on that last thread.
Thanks guys.. P2685 is a bigadv?
extra parameters is a must to run as a service, which is one of the principal advantages of 6.30 over the previous versions.
