I bar,y understood what you guys said....I'm a real noob! I need like step by step and very non pc builder language
I don't understand how to make it any more simple. Can you explain what ways we can simplify this for you? What don't you understand? Help us help you.
http://pcpartpicker.com/user/mistersprinkles/saved/mJG2FT
^This parts list would be very good.
To make it even better, leaving you open to unlocked 4 cores and multiple graphics cards, take the above build and swap the motherboard for an ASRock Z97 Anniversary. That'll be an extra $30 or so. I highly recommend that you do it. So altogether, $600. That's what I suggest you spend. Build the link above, and if you want some future proofing, get the ASRock Z97 Anniversary motherboard.
If there's anything you don't understand just ask us and we'll explain it to you.
I'll try to explain what we're all saying here.
Basically there are a few basic components to a PC
CPU
Motherboard
RAM
GPU
Power Supply
Case
Drives
The CPU is the mathematical "brain" of your computer. It does most of the "thinking". The motherboard is the largest part, and is where all the other parts interconnect. The RAM is the short and medium term memory of the computer. When the computer is about to use something or needs it handy, it stores it in RAM. Ram is different from Storage in that it erases when you turn off or reset the computer. The GPU is the graphical brain of your computer. It thinks about things you see on screen and is responsible for displaying images on screen. The power supply is responsible for taking 115V or 220V power from the wall and turning it into well regulated voltages like 3,5, and 12V, that the various parts of your computer require. Its important to have a power supply with enough watts and amps for the computer you are building. The case is the housing for all your parts. Things to consider in a case are looks, quietness, cable management options and air flow. Drives, like hard drives, optical (CD/DVD/Bluray), and SSD (solid state drives) are storage. Permanent storage that is. When you write something to an SSD, hard drive, or optical disc (like a DVD) it is there permanently. Optical drives haven't really gotten much faster over the years and can now be found for $20. They are going extinct since everybody buys software and games online now, but for a beginner it is wise to have one for windows install etc. SSD (solid state drives) are like hard drives in that they both store large amounts of information, but the hard drive is not as fast as the SSD. This is reflected in prices. For $100 you can have a 2 or 3TB hard drive, but only a 256GB SSD. With your budget, you can't really afford an SSD now but if you want to go along and be upgrading this computer, the upgrades I would do, in the following order, are:
SSD
$70-100
CPU (to an i5 like the 4690K)
$240
GPU (to whatever is the best GPU in your price range at the time.
$240-260 is the sweet spot usually with graphics cards where you get the most performance for your $. For example, currently that GPU is the AMD R9 290. Can be found for $229 in the USA)
Also if you will be upgrading in future (better GPU particularly) I suggest a better power supply. For the same price as the one I listed you can get a 500W Corsair CX500 which will be adequate for the i5 CPU and any GPU.
Here is the build with those modifications to make things easy for you, it has the Z97 motherboard, and the 500W power supply
http://pcpartpicker.com/user/mistersprinkles/saved/NcsMnQ
Don't forget to post in the Intel CPU section after you get the computer up and running to ask about overclocking your Pentium CPU. You can get a ton of extra performance out of it and it is very easy to do.
