- Jun 13, 2007
i know that the stock top pump is still a great pump so any extra performance from the top is icing on the cake. i'm not sure but i think they use the same design for the bay res as the single pump top's. either way you will get great performance from it.
and since your changing the top of the pump you will be able to use any barbs that work with G1/4 thread. so 3/8" or 1/2" will work just fine.
you can still use the ek res as well as the XSPC bay res, but there is no point other then looks. i would only get the one though.
