- Oct 2, 2019
- Thread Starter
- #21
what i7 do you have they range from 93w to i think like 150w!? the 2080 is 215w so if the "i7" is a 9700k that's 95w, you are at 305w right at the cusp of what is recommended for a 360mm radiator they generally recommend 120mm of radiator per 100w, more if you want it quiet AND cool.
The software is picking the processor up as an i7-9700K. So I am assuming that is what it is. Thanks for figuring that out for me. I did not know the wattage of either part before. Please correct me if I am wrong, but I am guessing I can not / should not overclock it on the slim 360. The fans are pretty quiet during normal usage. They get going a little when I play, but I still don't think I have ever seen them max out. The pump speed is one thing I don't know much about. I have it plugged in to the CPU opt slot, but I am not liking that, as it does not respond to GPU temps, and the GPU temps are the ones that vary more with usage / are closer to problematic.
While I am not prone to overclocking it, I feel like its stupid to have a water cooled system that can't be overclocked. So, my guess is that I will probably add more radiator to it, even though I really am not sure the cost is justified given my usage pattern.
