Then why do they charge a premium for overclocked cards if they could overclock to SC SSC FTW or Classified with all there testing binning? You have to remember all I do also most people do is plug and play no fan ramping or extra cooling and works on all games, some of the games I have seen memory artifact minor some times. Also the big spot for me is when a new demanding game comes out I had 2 different modes of EVGA SC lockup on me and they sent me a new one because when I under clocked to stock it would paly fine on both. It's all about plug in case no mater what the temp is and get the overclock rated without boost. For 30 years I had my case cover off no fans except the CPU. With one fan and the case closed I get no boost speed, however my GTX 970 EVGA always gets the max boost of 1418Mhz with cover off and the fans don't ramp up that much, you can here a pin drop.
We all forget the key to overclocking is cooling and voltage and they have done a fine job with big high teck heat sinks and dual fans.
Most people in the know like you do close cases with a lot of fans and nowadays test bench with one fan, I don't need a fan heat rises and I get fresh air all the time.
Looking at average results on all GTX900 cards I can say that only EVGA Classifieds/KPE are really binned and have higher ASIC. All other cards have random ASIC. You can get everything regardless what series you buy.
Not sure what your point is here?I called EVGA by phone and they say they test every overclocked card they sell to grantee it will overclock to the rated advertised overclocking.
That was my point originallyWingman they will only run the advertised speed is what EarthDog is saying. That's the ONLY guarantee
Well my point is when EVGA test the GPU's some must fail the test for overclocking. I will have try and find out if EVGA Bin the GPU's or TSMC does the binning for EVGA.Not sure what your point is here?
That is the binning process. If it says it run at XXXX/XXXX on the box, it will run those speeds.
Just have one thing say, I know how binning is donealong with what you said they also bin with the thermal threshold testing.Yes, those that may not pass at say, SSC levels may pass at SC levels or even lower, reference clocks. It gets labeled as such. It's how binning works. It has to fit within clock speed and power thresholds to make each bin.
But we are again getting off topic...
Well that;s a glass half empty take....actually now might be the best time to grab used cards before the benchmarks come out and people get disappointed over nvidia claims
