- Mar 7, 2008
In the last year, nVidia has added the code to support Freesync to their drivers (since after all it's open source). The part I'm not clear on, is if it can actually be enabled on *any* Freesync monitor, or only supported ones. nVidia also released a list of "Gsync compatible" monitors. These are just Freesync monitors that passed nVidia testing and supposed to work well with nVidia cards using the Freesync protocol.
For supported GPUs with a new enough driver:
If the connected monitor is certified G-sync compatible, it "just works" and is activated by default.
If the connected monitor is FreeSync compatible but not certified G-Sync compatible, the user can manually turn it on.
Second question: Do the panel manufacturers need to pay for the "gsync compatible" testing or the use of the marketing language? Is this a licensing issue? In that case how is nVidia charging to license compatibility with open source software that was developed by their competition (again going on memory here). If so that also seems wrong.
G-Sync Compatible is not equivalent to saying it works with FreeSync. I'm calling it GSC for short from now as I'm not typing that every time. GSC means it not only works, but the monitor itself is of some high standard of image quality that is comparable to native G-sync displays.
When GSC was introduced, nvidia were testing all available monitors out of their own (very deep) pockets. Certified monitors would be enabled in driver. The list was very short. I don't know if the monitor manufacturers were involved in this process, at least for displays already in the market.
For new monitors that were being developed, it is conceivable the manufacturers would work with nvidia to try for certification before launch. I don't know what that process is, or if anyone needs to pay anyone. I doubt it would work out to be a significant revenue stream for nvidia, so they may choose not to charge for it in the hopes of increasing adoption.
It is fair to assume that as G-sync is an nvidia owned IP, there would at the least be some legal agreement between nvidia and display manufacturers in order to use the logo.
