- Jan 12, 2013
- Pittsburgh, Pa
Hi guys,
I finally decided to go out and upgrade my PC case so I would have some more room for water cooling. I ended up getting a leak in my H220 radiator so I ordered a 120x3 radiator from Swiftech with an integrated reservoir. I got it all hooked up and mounted up top of the NZXT Switch 810. I have always had a big dust problem in my house. I just replaced the furnace filter with a really good filter but that did not seam to help too much. Anyways the dust is getting past the dust filters it the 810 switch and it is already pretty dusty inside from about a weeks worth of running. I noticed a lot of dust on the front bottom right corner where the dust filter does not protect. I don't know why they made that filter like that. Below is how I have things setup.
I have 3 Switech Helix 120's on top and 3 on the bottom of the radiator at the top. Then, I have the original rear 140mm exhaust, two 140's in the front, and one 140 in the upper spot that is used to cool the GPU/CPU. I have ordered 3 more NZXT 140mm fans to use as well. Anyone got any ideas on what I can do to stop this from happening? I am getting really tired of all the dust and can't seam to come up with a way to get rid of it. Over the years I have tried everything I can possibly think of. Would buying a air purifier for my living room help at all? That is where I have my PC at. The living room is pretty big. I think it is like 10x20. If a purifier will help can anyone recommend one?
Thanks,
Rocky
Thanks,
Rocky
