hello guys
recently i overclocked my phenom x2 using auto overclock utility in my bios.
it overclocked to 3359 mhz,after testing on prime 95 for like 12 minutes temp was idle 76c
i know thats alot of heat,this is because im using stock cooler with almost no thermal paste.planning to change my cooler in 1 or 2 weeks
so should i stick with this overclocked frequency? or try to go for more using manual override?
i also tried to unlock core using asus core unlock utility and it went pretty well,but as you know i dont hav enough cooling,so on prime 95 it crashed after continuously rise in temperature to 90c and then i went back to 2 cores after resetting bios.
so suggest me guys,what should i do.(system specs are in siggy and im using 2 ram sticks in single mode)
here are some pics might help.
1.after overclock with 2 cores and on prime 95
http://imageshack.us/photo/my-images/822/capture1aw.jpg/
2.without prime 95 on idle with cpu-z stats(after overclock ofc.)
http://imageshack.us/photo/my-images/820/capturekbl.jpg
ty
ty
