There's always a chance that once you unlock the cores on you're processor, one or both of the unlocked cores may be defective, you can test this by doing a long prime 95 test (2hr+) and see of it passes but due to you're cooling problems at the moment that is not an option for you right now, but you may have a defective core that caused you're CPU to shut down (bsod) or it may need more vcore to run unlocked and it has revert to stock fail safe settings on its reboot, which it does if it can't boot back in at the original settings you used, once you get you're new cooler and get you're temps under control then you will be able to test you're unlocked cores for viability, but until then it's just a guess as to what caused it.
