- Thread Starter
- #21
Hi,
yes that’s the "classic" one. I`ve had it like this before.
But how fans are places and if the pull air in or out makes sometimes a "great" difference.
An example (sorry it is written in german, but down you can see the pictures and the table with how the temperature is) is this: Klick me. But don`t forget: It´s water cooling used here.
Back to the picture you posted. Atm I have:
One front fan which pulls air in.
One side fan (left bottom) pulling air in direction of graphic card.
Up left case one fan, which pulls air out. right of it the CPU cooler with another fan, which pushes it to the up left case fan.
One fan above the CPU cooler, which pulls air from outside to the CPU cooler.
I`ll make some photos at home so you can better imagine what I`m trying to tell you.
Actually I’m not sure with puss and pull, so I`ll add some arrows in which direction air goes.
P.s.: New graphic card added: Sapphire Vapor-X Radeon R9 290 Tri-X OC, 4GB GDDR5, 2x DVI, HDMI, DisplayPort, full retail (11227-04-40G). Problem: his one doesn`t push/pull air out of the case, so maybe I have to change the left down fan direction?
