Hey guys, I'd appreciate your input here. As the thread title denotes, I have an E8500 with an Asus P5Q-E motherboard. I'm looking for 4 Ghz. I suppose I'd settle for 3.8, but I'd like to hit 4. I'm not really trying to push past 4 Ghz just to be safe. Sadly I do not have the E0 stepping model. I have never OC'ed before, and this is my first full build. What I need your help on is what settings to change in the BIOS. I understand it is bad to leave voltage settings and possibly some other settings on AUTO when OC'ing.
System specs
P5Q-E (1201 BIOS)
E8500 C0
Tuniq Tower w/ TX-2
4GB Corsair Dominator 1066 2 x 2GB (not using the airflow fan)
Corsair 550VX
VisionTek 4870 512MB
Four 120mm case fans and one 80mm case fan
Current SpeedFan temps idle/load (using Prime95 for load)
System: 21C/21C
CPU: 25C/31C
Core0: 31C/40C
Core1: 36C/41C
CPU-Z data
Core Voltage: 1.136 (@ 3.16 Ghz), 1.120/1.128 (@ 2 Ghz) w/ Speedstep & C1E enabled
The FSB and multiplier are both on AUTO in the BIOS (333 & 6.0/9.5). I'm aiming to set the FSB to 425. So the big question is...what should I change the voltage settings to? Not just the CPU voltage, but all that apply. NB, PLL...etc.
Thanks in advance guys!
System specs
P5Q-E (1201 BIOS)
E8500 C0
Tuniq Tower w/ TX-2
Corsair 550VX
System: 21C/21C
CPU: 25C/31C
Core0: 31C/40C
Core1: 36C/41C
CPU-Z data
