it would be lot easier to OC with multiplier, just raise multiplier, check stability and add voltage when needed, then fine tune your OC with NB frequency and voltage.
if you use FSB then you are Oclocking almost evey parameters of your system, RAM, NB etc whuich needs to get adjusted to keep within the range.
Unlocked multiplier = Black edition. use it.
