Rgone is the man!!!!
where do you get the info, when i go searching for these detail things i just get gobble-de-gook?
my sabertooth only allows the vcore to be adjusted with the + and - keys and i think the adjustment is .0125 and his might be the same manner.
i guess i need to fire up my 955 when he posts his next stress test to compare vcore.
I had to add 0.25vcore to achive the 18.5x210In post #13 "zipperdb" says > I made it to x18.5 and fsb of 210 @3.9ghz but then i need to add 0.250 to the vcore or else i get blue screens. = So that sentence leaves me guessing. Did you mean that to run 18.5x210, you MUST ADD 0.25Vcore. Or did you mean that to go 'higher' than 18.5x210, then you must add 0.250Vcore. There is a huge difference in what that sentence might mean.
I can add 0.125vcore that was not enough to achive 18.5x210Another thought comes to mind. Why do you mention adding 0.250 Vcore? Are those the only 'increments' you can choose in the bios? Does the motherboard bios only allow you to raise Vcore in 0.250 increments or can you raise Vcore by a lesser amount?
thats because i didnt fully check or it was stableWhere are the screen captures of the three tabs of CPUz and HWMonitor when you were running 18.5 x 210 = 3885Mhz? You show us the four captures for 18.5 x 205, but you do not show us 18.5 x 210.
zipperdb said:I made it to x18.5 and fsb of 210 @3.9ghz but then i need to add 0.250 to the vcore or else i get blue screens.
