- Aug 16, 2009
We all run a combo OC ..... meaning we use some FSB and Multi to achieve our OC's. It seems once you pass a certain speed it becomes harder to get your next multi, for me that was with my 8350 around 4.8GHZ switching to a combo OC it was allot easier to get the next big step with my OC. This is something you probably would not of noticed with your AIO cooler had you not beefed up your fans to get that little extra bit of headroom. It has been noted before that there is some advantage in regards to heat generated it's not huge but there none the less you might as well take advantage of it. I had a rough night sleeping last night with the humidity storms and heat my mind is not working right yet I am sure you will get a better response yet, me I am not the terminology guy that I leave to RGone ...... he's the man.
