- Aug 8, 2003
- Offical DFI Rep! Ask me!
Hi all, my name is Travis H, aka Angry_Games.
I work for DFI, makers of the LanParty and Infinity motherboards. I won't bore you with my yapping other than to tell you don't be afraid to ask questions =)
I do work for DFI in case anyone missed that. Normally I work the AMDMB.com forums here:
http://forums.amdmb.com/forumdisplay.php?s=&forumid=66
Many of you know me from my postings here, and OC was kind enough to put a DFI spot in here, so I will try to hit it regularly. Always remember if you want, you can contact me via email, msn, or through OC forums or AMDMB forums.
I do support Intel motherboards, and though OC forums has them divided from the Intel section, it would help me greatly if you posted any Intel related questions here as I hate having to look at 6 different areas to find DFI stuff, and the search feature here won't let me use DFI as a search term!
So remember, I do work for DFI and will help you with your DFI board any means within my power! And lets try to stay on topic in the main threads, and I will create a 'bar' type place for DFI users to just yap about anything if you guys are ok with that.
IF YOU DON'T ASK, HOW CAN YOU GET AN ANSWER?
Travis H.
DFI Support
www.dfi.com.tw / www.lanparty.com.tw
Travis H.
DFI Support
